LabWindows/CVI
Scrolling A Panel Under Program Control
In my program I've created a panel that contains a table. Since the table is larger than the viewing area (screen height) I added a vertical scrollbar to the panel.
The panel scrolls properly using the mouse but I'd also like to be able to scroll the panel under program control. For example - move the viewing area to the top of the panel if a certain action is performed.
Any thoughts?
George Hodgson
(3,584 Views)
George,
You can scroll the table programmatically using either the following attributes:
SetCtrlAttribute (panel, table, ATTR_FIRST_ROW_VISIBLE, );
SetCtrlAttribute (panel, table, ATTR_VSCROLL_OFFSET, );
Luis
NI
(3,579 Views)
Luis,
Thank you kindly! A good case of my not reading through the attribute list
in the documentation properly. As you know, but perhaps others might find of
interest, the attribute ATTR_VSCROLL_OFFSET also works with
SetPanelAttribute.
George Hodgson
"LuisG" <x@no.email> wrote in message news:182496@exchange.ni.com...
> George,<br><br>You can scroll the table programmatically using either the
following attributes:<br><br>SetCtrlAttribute (panel, table,
ATTR_FIRST_ROW_VISIBLE, <row index>);<br>SetCtrlAttribute (panel, table,
ATTR_VSCROLL_OFFSET, <offset in pixels>);<br><br>Luis<br>NI
(3,571 Views)
