LabWindows/CVI
Screenshots with CVI?
Greetings, maybe i overread something in the manual, but i need my application to save screenshots to disk at certain times. Fine, i thought as i read about the printpanel function. And it works, i have files from about 300k on my disk but the problem is i can't open them with any picture viewer.
Any idea what file-format the files are (BMP i guess) or with which application they can be opened?
Or another idea to make automatic screenshots to disk from my application?
Thanks for any help!
(3,679 Views)
PrintPanel is designed for printing (to files or printers). If you route the printing to a file, then you get a PostScript file not an image.
If you want to save a bitmap image of your panel to file, then you can use the function SavePanelDisplayToFile which is in the Programmer's Toolbox (cvi\toolslib\toolbox\toolbox.fp).
Best Regards,
Chris Matthews
(3,679 Views)
Thank you very much for your fast answer :)))))
Best Regards
(3,679 Views)
Sorry, seems a was a little to fast. I am using CVI 5.0 and i am not able to find the function in the toolbox. Maybe it was implemented in a newer version.
Do you have any other idea? Simulating a keystroke to use a third party application would also do fine. But i only found vi's for LabView to do so.
Thanks for your help
(3,679 Views)
Sorry, you are correct, it was added in CVI 5.5 to the toolbox. Below is a program that will work in CVI 5.0. I highly recommend upgrading though, there are enormous improvements in CVI between 5.0 and 6.0.
Best Regards,
Chris Matthews
(3,679 Views)
Chris,
I have been trying to do this for days. I was about to spend money on an application which would allow saving off controls and panels to bitmap files. Thanks for the help.
(3,679 Views)
