LabWindows/CVI
SQL toolkit Vista and windows 7 problem
Hi all.
I have a program that uses the SQL Toolkit, Its works like a dream on Windows XP.
But when i try to run the app with the same ODBC setting as xp on Windows Vista and 7 i cant connect to the database.
Does anyone know why this is happening and a solution if you have one ?
Code:
DBInit (DB_INIT_MULTITHREADED);
DatabaseHandle = DBConnect ("DSN=ITAGv11");
if (DBError ())
MessagePopup("Error","Database connection problem.");
I have attached an image of my ODBC settings.
Thanks in advance.
Help share your knowlegde
(3,370 Views)
I haven't run into any database issues, so if someone else has additional experience, please add their comments/experiences. Can you run any of the database examples provided with CVI. Also what version of CVI are you using?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,339 Views)
