LabWindows/CVI
SQL toolkit DBMoreResults()
the function DBMoreResults() from sql toolkit seems to be buggy as hell.
1: It does NOT return a valid (eg. DB_EOF) return code if there are no more results.
    Given a stored procedure like:
CREATE PROCEDURE `test01`()
BEGIN
                SELECT 1 FROM DUAL;
                SELECT 2 FROM DUAL;
END;
and a (pseudo) code routine like
                if((hndDB = DBConnect (strDBConnect)) > 0)
                                 if((hndStmt = DBNewSQLStatement (hndDB, "test01()")) > 0)
                                                  iDBRetCode = DBSetStatementAttribute (hndStmt, ATTR_DB_STMT_CURSOR_TYPE, DB_CURSOR_TYPE_FORWARD_ONLY);
                                                  if(iDBRetCode == DB_SUCCESS) iDBRetCode = DBSetStatementAttribute (hndStmt, ATTR_DB_STMT_LOCK_TYPE, DB_LOCK_READ_ONLY);
                                                  if(iDBRetCode == DB_SUCCESS) iDBRetCode = DBSetStatementAttribute (hndStmt, ATTR_DB_STMT_COMMAND_TYPE, DB_COMMAND_STORED_PROC);
                                                  if(iDBRetCode == DB_SUCCESS) iDBRetCode = DBOpenSQLStatement (hndStmt);
                                                  do {
        if( iDBRetCode != DB_SUCCESS ) break;
        // bind those columns
    // BIND VARIABLES TO THE RESULT SETS ('1', '2')!!!!!!!!!!!!!!!
        while(( iDBRetCode = DBFetchNext (hndStmt)) == DB_SUCCESS)
    // DO SOMETHING WITH THE RESULT
        } // end while dbFetch
        if( iDBRetCode == DB_EOF ) iDBRetCode = DB_SUCCESS; // DB_EOF is NOT AN ERROR!!!
    // NOTE THE FOLLOWING LINES
                                                  } while(( iDBRetCode = DBMoreResults (hndStmt)) == DB_SUCCESS );
    // Workaround for DBMoreResults - bug
                                                  if( iDBRetCode == -10 || iDBRetCode == -11 )
        iDBRetCode = 0;
    // END NOTE
                                     DBCloseSQLStatement(hndStmt);
                                     DBDiscardSQLStatement(hndStmt);
                                 } else {
                                                  iDBRetCode = hndStmt;
                DBDisconnect(hndDB);
you will see that the do - while loop will be executed 3 times!!! that's once too often since there are only two result sets generated by the stored procedure.
Even worse is that the DBMoreResults() function returns DB_SUCCESS all the time until the 3 loop, then the return value is -10 or -11 (system error!!) which
can't be distinguished from a real sytem error any more.
2. After working with the above workaround everything went fine til the returned resultsets grew in size and now the DBMoreResults() - beast returns an ODBC
error which may be true, or not.
All this was tested with CVI 8.5.1 and the latest SQL - toolkit, MYSQL 5.1 and MyODBC 5xxx (latest version, supporting multible result sets)
thx for help
Message 1 of 1
(3,070 Views)
