LabWindows/CVI
SQL Toolkit ATTR_DB_CONN_COMMAND_TIMEOUT
Does anyone know what the default value of this attribute is?  Occasionally I get a timeout error and I'd like to increase the value but I don't know what the default value is.  Thanks.
(3,097 Views)
Hi CareFish,
I haven't ever looked into that attribute, but I did a quick search for ATTR_DB_CONN_COMMAND_TIMEOUT on our website and this KB came up. It appears that the default value is 30 seconds. Searching the error code that is returned usually nets some good results as well. Happy programming!
Cheers,
KyleP
(3,093 Views)
