LabWindows/CVI
SCXI Hardware Multiplexing
I am at present using SCXI-1100, SCXI-1102, SCXI-1126. I am planning to multiplex all these channels onto PCI-6071E DAS Board Channel 0. My Application is being developed using LabWindows/CVI. I have to acquire from each individual SCXI channels at the rate of 1000 samples/sec.
But I am unable to accomplish the same. In my program I am using Timer() function as I have turn on certain relays with reference to time. My application is very time critical and relevant data is available for 1 second only within which I have to acquire all of them & also do some control.
Kindly let me know how do the same using SCXI Hardware channel scanning. It would be appreciate if you can send me example demonstrating my requirement.
(3,148 Views)
Hello Rajinikanth,
Thank you for contacting National Instruments. You should be able to achieve a sampling rate of 1000 samples/sec on each channel you are using with your hardware. I did find an example that you should be able to use as a template to start out. It is located at:
\daq\scxi\SCXI_SCANsingleBuf.prj
However, this example does use a buffer, which means that while you will be able to read at a very specific rate, there may be a delay between the time at which the value read at the SCXI module is actually processed in the computer. This means that if you are doing a control loop, it would be better to use a slower, non-timed acquisition with a simple control loop. If you have some sort of control loop, you should try to use the example:
\daq\scxi\SCXI_AIOnePt.prj
Notice, however, that with this example you will not get 1000 samples/sec.
I hope I have explained this well. If this doesn't help, you may want to contact National Instruments at www.ni.com/ask and explain the exact difficulties that prevent you from accomplishing this task.
(3,148 Views)
