LabWindows/CVI
Runtime errors between LabWindows/CVI v.6.0 vs. v.8.1; Error code -114 from Load Panel (format of the file is newer than this version of CVI)
A Distribution Kit, previously created with LabWindows/CVI version 6.0, and now created with
LabWindows/CVI version 8.1, only executes on the machine with the newer version.
The error is also received when the application is installed on a machine without
LabWindows/CVI installed.  It was my understanding that the Distribution Kit would
contain the proper runtime support, so something is very wrong.
The error received is:
"Error in call to LoadPanel"
Parent Panel Handle: 0
UIR file Name: ADLS.uir
Panel Resource ID: 13
Error Code - 114
The Format of the file is newer than this version of the CVI
(4,897 Views)
That error indicates that version 8.1 of the CVI runtime engine is not being installed by the distribution kit.  Here are some steps which may help determine why:
1. Take a look at the Drivers & Components tab of the Edit Installer dialog and confirm that you have some form of the LabWindows/CVI Run-Time Engine checked.
2. If only the Standard Run-Time subitem is checked, try checking the top level LW/CVI Run-Time Engine item (will select all subitems), rebuilding, then redeploying your distribution kit.  If this works, it indicates a problem with deploying the runtime engine in merge module form.
3. Create a distribution debug log and post it here for me to take a look at.
Thanks.
Mert A.
(4,891 Views)
Thank you for your help and suggestions, Mert!
The problem was indeed with the bundling of the run-time support.  Your suggestions made me look more
closely at the Distribution Kit set-up, and I found that in fact, I was still building my Distribution Kit under
Labwindows/CVI version 6.0!
The new installer built under 8.1 was noticeably different, and, lo and behold, had much more depth in the
run-time support.  It now executes without error.
Thanks, again.  LPR
(4,867 Views)
