LabWindows/CVI
Run-time box in middle of screen
For some reason I get this RunTime box in the middle of the screen I am in DeBug Mode in 8.1.0 LabWindows/CVI. in the many systems I have built for the lab at least 2 have this annoying box that pops up when CVI is launched. if clicked on to close or terminate, CVI is terminated. Does anyone know how to fix this?
JPG attached...
Message 1 of 8
(7,783 Views)
Do you get the window when you run in release mode? What commonalities exist between the two programs that exhibit this behavior that set them apart from your other programs?
Adam
Message 2 of 8
(7,732 Views)
Yes, when I run a released (.exe) program on this PC (one that requires the CVI RTE) the little annoying box come back...  on all the other stations I have 8.1.0 loaded on this does not occur, even using the same program.
Message 3 of 8
(7,730 Views)
Hello Asic,
just letting you know that I am dealing with the same problem. On some systems the box is there, on most systems not. Even with the same CVI application. When the user closes the box, the application just quits... Smiley Sad
Message 4 of 8
(7,717 Views)
This window is part of CVI, and part of the CVI run-time engine. Normally, it is displayed well off-screen, and can't be activated, therefore no one would ever be aware of its presence. The most likely reason why it might be visible in your case would be if your video adapter has an option to move off-screen windows into the visible area of the monitor. If you can, I would suggest that you modify this option in the video adapter to not do this for CVI (I'm assuming that it allows you to specify applications for which you don't want this feature). If that's not possible, then disable this option altogether. CVI will probably change in the future to not require that this window exist, but until then, the only solution is to disable the option.
Luis
Message 5 of 8
(7,692 Views)
Thanks Luis,
    You are correct.... this is a DUAL monitor system, all of my systems are Dual monitor so I guess if I position my monitors in the correct configuration, this box would be off screen...
Chip
Message 6 of 8
(7,686 Views)
Thanks a lot for the explanation, Luis!
Message 7 of 8
(7,651 Views)
Accepted by topic author ASIC_LabRat
No longer an issue with 2009 "Ding Dong the Box is Gone!" Smiley Very Happy
Cheers!
Chip
Message 8 of 8
(6,709 Views)
