LabWindows/CVI
Ring control needle color does not always update properly
I have a ring control that I am trying to programmatically change needle color on.  A separate control makes the needle transparent, and my intent is that clicking anywhere on the ring control will return the needle color to red. I have this set up through an "EVENT_LEFT_CLICK_UP". However, the only time that the needle color actually changes is when you click on the outside edge of the control. Sample project showing the behavior is attached. Any advice?
(2,269 Views)
Hi,  interesting behavior, let me play with it.
And see if there is another function relate.
(2,234 Views)
