LabWindows/CVI
Remove Frame on Slider Component
I have a Numeric Slider Component on my application used as a Progress bar. Everything is fine until it gets to the end (of loading) and a red frame appears around the component. Any idea how to get rid of this? Probably a simple solution,
but can't seem to find the right attrribute in the library.
I have tried the ATTR_FRAME_COLOR attribute but no luck.
Much appreciated.
(3,225 Views)
Accepted by topic author ApeKind
That red frame is there as a warning to the user that the control's value is out of its limits.
You should either change the control's max/min values or disable range checking.
See the figure:
Edit Numeric
S. Eren BALCI
IMESTEK
(3,223 Views)
Ahh Ok, that makes sense. Thankyou for the advice.
Cheers
(3,221 Views)
