LabWindows/CVI
Release - SQLToolkit
Hi!
In debug mode my program works properly. In the release version, it freezes when I try to connect and read the Access database. There isn't any output error.
Does anyone know what is the problem?
Thank you in advance.
(3,255 Views)
Have I add any files in the installation package?
An important information is that when I install the aplication in my machine, which has CVI and SQL Toolkit installed, the application works perfectly. In machines that do not have CVI this feature does not work.
Message Edited by Oliveira on 10-10-2007 01:56 PM
(3,243 Views)
Hi Oliveira, good morning.
If i understood it well, you´re trying to build an executable to run in a PC that doesn´t have LabVIEW.
First, be sure that you have all the necessary to build this, driver, LabVIEW Professional or Application Builder, and doing all the steps rightly.
Maybe its happening because of the driver or the way your database comunicates with LabVIEW.
Reffer with this link below from NI site:
Let me know if you have more doubt or its not succesfull.
Filipe Martarello
Applications Engineering
NI Brazil
(3,200 Views)
