LabWindows/CVI
Regex replacement syntax in editor
Hello all,
for the life of me I can't remember (nor find in the documentation) the syntax for doing string replacements using regular expressions in the CVI editor.
Something like:
Search: ({[~,]*},
Replace: (\1, A10,
Would change the string "(aei1," to "(aei1, A10,"
But what are the delimiters to use ? {} like in my example ? And what's the variable ? \1 ? $1 ?
I just can't find it.
In sed syntax:
sed -e "s/(\([^,]*\),/(\1, A10,/"
(5,094 Views)
(5,091 Views)
No, it's not in there. Here's the relevant doc from sed for what I want:
       s/regexp/replacement/
              Attempt to match regexp against the pattern space.  If successful, replace that portion  matched  with  replacement.   The replacement  may contain the special character & to refer to that portion of the pattern space which matched, and the special escapes \1 through \9 to refer to the corresponding matching sub-expressions in the regexp.
I'm sure I've used it with the CVI editor before.
(5,072 Views)
Take a look at this stack overflow post: http://stackoverflow.com/questions/8044081/how-to-do-regex-string-replacements-in-pure-c
Is that what you're looking for?
Kelsey W.
(5,039 Views)
Well, no, I was just looking to do it in the CVI editor. It's OK, I just used a perl one-liner on my source code and changed all the lines I wanted. I used the following to add an argument to a function:
perl -i -p -e 's/MyFunc([^,]*,[^,]*),/C\1, NEWARG,/g' *.c
(5,031 Views)
