LabWindows/CVI
Regarding values in an indicator
I am entering a value in a string control as 1. As per our requirement, this value is fixed. I have entered the value and I have closed the application and I have opened the same application, the next day.
But there is no value which I have entered in the string control.
The value should be seen by the user.
How can i do this in LabView?
Thanks in Advance
Regards
Malleswari
(2,956 Views)
Hi Malleswari, you should post this question to the LabVIEW forum, instead of this CVI forum.
(2,952 Views)
