LabWindows/CVI
Refresh Graph with user-defined range and scale
I tried to read the input data from the panel and refresh the plot but met a strange problem: it can only response correctly when the input numbers starting from "1". Here is a test,
step1: "start=1000,stop=100000"  shown correctly
step2: "start=2000,stop=50000" stays the same, no change
step3: "start=10000,stop=1000000" updated correctly
Is it possible that I forgot to set some attribute in the following codes?
        GetCtrlVal(figure_handle,FIGURE_START,&start);
        GetCtrlVal(figure_handle,FIGURE_STOP,&stop);
        SetAxisScalingMode(figure_handle,FIGURE_POWERGRAPH,VAL_BOTTOM_XAXIS,VAL_MANUAL,start,stop);
        GetCtrlVal(figure_handle,FIGURE_SCALE,&i);
        switch(i)
        case 0:
            SetCtrlAttribute (figure_handle, FIGURE_POWERGRAPH,ATTR_XMAP_MODE, VAL_LOG);
            break;
        case 1 :
            SetCtrlAttribute (figure_handle, FIGURE_POWERGRAPH,ATTR_XMAP_MODE, VAL_LINEAR);
            break;
Thanks for your help,
wmf
(3,057 Views)
If you are using log scales, then yes, CVI only supports powers of 10 for the maximum and minimum of the axes (it is a base-10 logarithm). When you try to set the range to something else, the graph will coerce the values to the nearest powers of 10.
Luis
(3,049 Views)
