LabWindows/CVI
Redirecting output from command prompt and saving it to an array?
Hello everyone,
I have a program that executes a file, and have used the following code to run the file:
int exec=0;
LaunchExecutableEx ("cmd.exe /c config.exe parameters ", LE_HIDE, &exec);
When the config.exe is ran, it generates output on the command screen which I would like to redirect and store in an array. Is this possible?
I am trying to avoid redirecting the output to a file and storing it from there.
Thanks!
Message 1 of 8
(5,681 Views)
Hi!
Could you elaborate on why this is needed? The current methodology I can see working is using pipes, this is discussed in the below linked stackoverflow thread:
https://stackoverflow.com/questions/1404189/how-to-read-redirect-output-of-a-dos-command-to-a-progra...
Although I believe popen would only redirect the settings when the pipe is closed. To get continual data I would try looking into the first suggestion of passing a STARTUPINFO structure with the handles. There is a microsoft example from first glance:
https://support.microsoft.com/en-us/help/190351/how-to-spawn-console-processes-with-redirected-stand...
Hopefully this will help provide a solution,
Ed
Message 2 of 8
(5,640 Views)
Hello Ed,
Thanks for the response. I've tried using popen but it doesn't seem to be supported in LabWindows. Whenever I try to compile the program, it doesn't recognize that function. Do you have any idea why?
Thanks!
Message 3 of 8
(5,621 Views)
You will need to include the headers for this Windows function which is included in the requirements section for the MSDN page:
https://msdn.microsoft.com/en-us/library/96ayss4b.aspx
Message 4 of 8
(5,616 Views)
I've included all the required headers, and still get this message:
20, 17 error: implicit declaration of function '_popen' is invalid in C99. Make sure that you include the function prototype.
Thanks again for all your help I really appreciate it!
Message 5 of 8
(5,610 Views)
These issues are C and Win32 based and not explicitly LabWindows/ANSI C, the solution is to declare the function as described in the below thread:
https://stackoverflow.com/questions/15850042/xcode-warning-implicit-declaration-of-function-is-inval...
Therefore include just after your header declaration and before main, the line:
FILE *_popen(
const char *command,
const char *mode
Message 6 of 8
(5,605 Views)
So I tried that, and then I received this error:
error: Undefined symbol '__pclose' referenced in "c:\Users\mjj\Desktop\test\cvibuild.test\Debug\test.obj".
error: Undefined symbol '__popen' referenced in "c:\Users\mj\Desktop\test\cvibuild.test\Debug\test.obj".
Is there a library I have to include?
Thanks again for your help and your fast responses!
Message 7 of 8
(5,603 Views)
I was unable to get _popen to work, but ended up finding a code someone had written that performed exactly what I wanted to do, and it works great. Below is the link to that code:
https://cboard.cprogramming.com/windows-programming/65209-encapsulating-cmd-exe.html?highlight=creat...
Thanks again for all the help!
Message 8 of 8
(5,586 Views)
