LabWindows/CVI
Record sound?
Anyone know how to record a sound from the microphone input to either a wav
file or directly into an array?
I would prefer not to use MCI (as it is old and unpredictable from one PC to
another).
(4,599 Views)
Hi Alex,
Please find attached a sample of a vi which will do this - it records a snapshot of sound from the mixer (you can specify how long and at what sample rate), displays it on a waveform graph and replays it through the mixer.
It is currently saved for LabVIEW 8 - please let me know if you need another version, or have further questions.
Many thanks,
MarkL
(4,571 Views)
Since we are on the LabWindows/CVI board, how about a CVI version?
JR
(4,559 Views)
Hello Mark,
Could you post this file saved for Labview 7.1?
Celso
(4,453 Views)
Hi Celso,
I should really post this on the LabVIEW forum, but am having problems posting on there at the moment!
I've re-written the sound recorder in LV 7.1 for you, this version records a set amount (in seconds) of audio from the soundcard, displays both channels on a waveform graph and writes the data to a .csv file. The file writer vis can be substituted with vis to write the sound to a waveform file as required.
I hope this helps!
Mark
(4,409 Views)
i use best sound recorder and it's great. go to
http://www.best-seller-reviews.com/soundrecorder/ and download best
sound recorder program.
(4,392 Views)
