LabWindows/CVI
Real Time PlotXY
Hi, I'm trying to plot a real time line profile of a 640x512 image at 30 Hz (the line profile is only 640 pixels) and it seems that the plot just can't keep up.  Am I pushing the PlotXY function beyond is limits or am I just doing something stupid?  Sample code below:
startPoint = imaqMakePoint(1, rowToPlot -1);
entPoint = imaqMakePoint(640, rowToPlot-1);
spotImProfile = imaqLineProfile(camImage, startPoint, endPoint);
dataSize = spotImProfile->dataCount;
for(i = 0; i < dataSize; i++)
    spotProfileData[i] = (short)(*(spotImProfile->prfileData + i));
spotPlotHandle = PlotXY(panelHandle, PANEL, xProfileData, spotProfileData, 640, VAL_SHORT_INTEGER, VAL_SHORT_INTEGER, VAL_THIN_LINE, VAL_NO_POINT, VAL_SOLID, 1, VAL_GREEN);
DeleteGraphPlot(panelHandle, PANEL_SPOTIMGRAPH, spotPlotHandle, VAL_DELAYED_DRAW);
I don't have internet access on my programming machine so if I missd a tpyo its safe to assume the actual code is correct.
Graph settings are:
Control mode: Hot
Data mode: Retain
Smooth update: Yes
Has anyone else tried Real Time PlotXY with ~640 data points and updating at 30Hz?  My program runs fine without the plot.  Intermittantly the plot updates at ~30 Hz but for the most part it is 1 Hz at best.  Thanks!
FeralPhysicist
Message 1 of 8
(6,398 Views)
Slow graph updates may be a performance issue. 640 data points should not be pushing the limits of XYPlot function. Are you calling this function repeatedly? If yes, how often? Are you seeing any other performance delays besides plotting to the graph?
The LabWindows/CVI Help Manual page Programming with Graph Controls discusses ways to increase performance of a Graph Control. Disabling X-Autoscaling, enabling Anti-aliasing, and enabling smooth updating are three suggestions. There is also a section under performance in regards to optimizing memory usage. Improved memory usage can improve performance. Hope this helps!
Taylor B.
Message 2 of 8
(6,362 Views)
My program runs through the above code at 30 Hz.
I'll take a look at the link and reply if any of the hints in the link work.  Thanks!
Message 3 of 8
(6,359 Views)
I have tried all the hints (a actually was already using all the hints) and the program will still only run at about 1 Hz while plotting.  It runs great at 30 Hz if the only change I make is commenting out PlotXY and DelteGraphPlot.  I should mention that I'm using imaqGrab and imgPlot before the plotting each iteration.  Thanks!
Message 4 of 8
(6,322 Views)
If you comment out the PlotXY function, do you still see delays? I'm wondering if this is a problem with the IMAQ driver or LabWindows/CVI.
I'm not too familiar with the IMAQ driver functions. I do have the driver installed, but the Machine Vision forum may be a better place for IMAQ questions.
Taylor B.
Message 5 of 8
(6,306 Views)
If I comment out the PlotXY i do not see the delays.  In fact I can do an image subtraction, image cast, image treshold, get a line profile (but not plot them) of all 4 images, and plot 4 images to a canvas all at 30 Hz with absolutely no problem.  But when I comment out all the imaq functions except the imaqGrab and get a line profile (for only one image not all 4) and try to plot the single profile to a graph my program runs at about 1 Hz.
Message 6 of 8
(6,304 Views)
You could try using a StripChart instead of a Graph. The StripChart's scrolling mode could have an effect on the speed:
LabWindows/CVI: Programming with Strip Chart Controls
Perhaps a Producer/Consumer architecture would be best, where the data points (I'm assuming a 640x512 image means 327,680 data points) are stored in a queue and the plotting is handled in a separate thread. Here's some information about multithreading in LabWindows/CVI:
http://www.ni.com/white-paper/3663/en/
Taylor B.
Message 7 of 8
(6,300 Views)
You can speed up plotting somewhat by disabling the graph's smooth update and the copy original data settings. You should probably also disable auto-scaling of both axes, if you haven't yet. Plotting at those speeds is a blur anyway, and constantly updating the axis range would only serve to add more noise.
Also, make sure that no other control is overlapping the graph in any way.
Even if you do all that, you still might not be able to achieve 30 Hz plotting. But it doesn't make much sense to me why you have to plot at such fast rates. I understand that you have to run through your loop fairly quickly, but is there a reason why you have to plot every single frame? Why not plot only every 5th iteration, or something like that? I doubt that the human eye can keep up with a new plot every 33 milliseconds anyway (unless the data of each iteration is only slightly different from that of the previous iteration).
Luis
Message 8 of 8
(6,269 Views)
