LabWindows/CVI
Read value from Date Time Active X Control
Hello
I am using the Date Time Picker active control (MSCOMCT2.OCX) to show Date and Time. Please let me know how to read the value from this active X control.
Thanks and Regards
Rakesh
(5,129 Views)
Hello Rakesh,
If you are try to use the Date/Time Picker ActiveX control, you should do the following steps:
1. Get a handle to the ActiveX control.
int dateCtrl;
GetObjHandleFromActiveXCtrl (panelHandle, PANEL_CWDTPICKER, &dateCtrl);
2. Get the string value of the Date/Time Picker control and the integer value of the day, month, and year chosen.
int dayval, monthval, yearval;
char *stringval;
VARIANT dayvariant, monthvariant, yearvariant, stringvariant;
MSComCtl2_IDTPickerGet_Value (dateCtrl, NULL, &stringvariant);
MSComCtl2_IDTPickerGetDay (dateCtrl, NULL, &dayvariant);
MSComCtl2_IDTPickerGetMonth (dateCtrl, NULL, &monthvariant);
MSComCtl2_IDTPickerGetYear (dateCtrl, NULL, &yearvariant);
3. Convert the variant into a string or integer.
stringval = malloc(15*sizeof(char));
CA_VariantConvertToType (&stringvariant, CAVT_CSTRING, &stringval);
CA_VariantConvertToType (&dayvariant, CAVT_INT, &dayval);
CA_VariantConvertToType (&monthvariant, CAVT_INT, &monthval);
CA_VariantConvertToType (&yearvariant, CAVT_INT, &yearval);
As always, since the code set for this control is provided by Microsoft, you should first refer to the MSDN website / Google when trying to programmatically use these controls.  Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(5,115 Views)
(4,844 Views)
I am planning to incorporate the Date Timer Picker control (MSCOMCT2) into my CVI application.  On reading about, I see issues regarding its installation, registration, and distribution.   Do you and Wendy recall the details of your installation and integration into your application?   I have never used an Active X control of this sort before.
Thanks.
(4,843 Views)
