LabWindows/CVI
Read in a multiline csv file in Labwindows/CVI
  My csv file is formatted as such:
AID,partNumber,HardwareRevision
NHFH0A0165002050603333,68-0165-002,A
  I can read the first line in fine and split the csv string, but I am unable to read in the second third line (second line is blank space).  I have tried "While (!feof(fptr))" with no luck, goes into a continious loop and still only reads the first line.
  Any help would be greatly appreciated.  Thanks.
Chaz Byrne
  My current code:
#include <formatio.h>
#include <userint.h>
#include <ansi_c.h>
int main()
 FILE *fptr; //file pointer
 char string[2000];
 char item1[50];
 char item2[50];
 char item3[50];
    if ( (fptr = fopen( "C:\\AID.csv", "rt"))==NULL )
     printf("Warning: Problem opening file or file not found\n");
        return -1;
    fscanf(fptr, "%s", string);
     //while (feof( fptr)==0)
      Scan (string, "%s[xt44]%s[xt44]%s[xt44]", item1,item2,item3);
      printf("%s\n%s\n%s\n%s\n\n",string,item1,item2,item3);
    fclose( fptr );
    MessagePopup ( "Just to hold it...","Testing");
 return 0;
Output:
AID
partNumber
HardwareRevision
(4,634 Views)
fscanf(fptr, "%s", string); is what reads a line from your file into the string variable.  Scan() only parses the string for you.  You need to move the fscanf() call into your while loop to get a new line for each iteration.
Message Edited by mvr on 03-02-2006 02:13 PM
(4,634 Views)
