LabWindows/CVI
Read data using DAQmxReadBinaryI16
I'm using DAQmxReadBinaryI16 to read 8 channels data & save to file.
I modify the ContAcq-IntClk-EveryNSamplesEvent.proj, by changing
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,nSamples,10.0,DAQmx_Val_GroupByScanNumber,data,nSamples*numChannels,&numRead,NULL));
to
DAQmxErrChk (DAQmxReadBinaryI16(taskHandle,nSamples,10.0,DAQmx_Val_GroupByChannel,databuf,nSamples*numChannels,&numRead,NULL));
To scan 8 channels data, I set
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai7:0","",DAQmx_Val_Cfg_Default,min,max,DAQmx_Val_Volts,NULL));
Samples per Channel = 5000
Sample rate = 5000
I run the scanning for hours & save all 8 channels data (in short) everysecond.
I found data of 1 channel looks like this after 1 hour scanning.
First graph is plotting data from Channel 1, 2, 3, with same input.
Second graph is plotting data from Channel 2.
part of the data (in short & in double)
    chan 1      chan 2     chan 3        chan1           chan2          chan3 <-- after scalling using ScaleCoef
-162 -161 -161 0.073428 0.073757 0.073757
-159 -161 -160 0.074415 0.073757 0.074086
-159 -160 -159 0.074415 0.074086 0.074415
-159 -159 -159 0.074415 0.074415 0.074415
-158 -159 -157 0.074744 0.074415 0.075073
-172 -27 -164 0.070138 0.117849 0.07277
-161 -162 -158 0.073757 0.073428 0.074744
-170 -329 -164 0.070796 0.018478 0.07277
-185 -224 -174 0.06586 0.053027 0.06948
-184 -155 -185 0.066189 0.075731 0.06586
-205 -191 -193 0.059279 0.063886 0.063228
Message 1 of 1
(3,083 Views)
