LabWindows/CVI
Read a file between two lines
Can you tell me if, thank's to a function, we can read between two lines ?
For example, I have one file in.txt, it has 10 lines, and, I want to write what we have between lines 4 and 8 in an other file out.txt.
Thank's for your time
(3,052 Views)
Accepted by topic author Zerged
There isn't a native function that performs what you want but you can easily write one by yourself.
Something like this (pseudocode):
Open file for input (OpenFile)
Open file for output (OpenFile)
Read all lines one-by-one (ReadLine)
  Copy desired lines to oputput file (WriteLine)
Close input file (CloseFile)
Close output file (CloseFile)
Do not forget to add a proper error checking strategy to deal with I/O errors.
(3,042 Views)
answer is given here
(3,041 Views)
Yesss! That's the problem when posting the same question twice! Smiley Sad
In the future please do not repeat this: always post a single question in the international board, or post directly to the French board if you prefer your native language
(3,034 Views)
Thank's for your answers, I have found the solution ! 🙂
Ok I'll do not repeat this !
(3,023 Views)
