LabWindows/CVI
RS232 library threadsafe operation
Are there any concerns with using the RS232 library in a multithread operation as long as I do not attempt to access the same port from different threads? I am interested in using InstallComCallback to trigger on a received character. The multiple threads are generated by TestStand calling CVI routines for multiple UUTs in a batch sequence file model.
(3,655 Views)
No, the RS232 library is designed to be thread-safe and protect against simultaneous access.
Chris Matthews
(3,655 Views)
Thanks Chris,
I had one other related question on the InstallComCallback. How do the port timeouts interact with the callback function. I was looking for something in the EventMask that would allow a port timeout to trigger the callback, but I did not see any way of setting this up.
Scott Trosper
(3,655 Views)
The callback can't be used to detect errors (except line status errors). You would have to check for a timeout or other errors by checking the return values of your RS232 functions (like ComRd) or by using the ReturnRS232Err and GetRS232ErrorString functions.
Best Regards,
Chris Matthews
(3,655 Views)
