LabWindows/CVI
Question about controls
Dear sir:
I've used Measurement Studio 6.0 for a month or so. I should say it had improved a lot comparing with the former version. But I feel a little bit unconvenience about the ring controls. The arrow block attaching with the control can't be changed. No matter how big the control is, that arrow block'width keep still. I want to make it wider,but I can't.
So I will be very appreciate if you can make some change about this sort controls! thank you very much.
(5,612 Views)
If you have a plain ring (CTRL_RING or CTRL_RING_LS), use the following code:
SetCtrlAttribute (panel, control, 20472, newWidth);
If you have a menu ring (CTRL_RECESSED_MENU_RING, CTRL_MENU_RING, CTRL_POPUP_MENU_RING, CTRL_RECESSED_MENU_RING_LS, CTRL_MENU_RING_LS, or CTRL_POPUP_MENU_RING_LS) use the following code:
SetCtrlAttribute (panel, control, 20475, newWidth);
If you want to set the height of a menu ring's arrow, use the following code:
SetCtrlAttribute (panel, control, 20476, newHeight);
These are undocumented attributes, so you won't find their description in the function panel help or online help.
Luis Gomes
NI
(5,612 Views)
Hi Luis
Is it possible to dimm individual ring items ?
(3,674 Views)
CVI2012 provides this new feature, now you can use SetRingItemAttribute (, , , ATTR_DIMMED, ), e.g.
SetRingItemAttribute ( PANEL, PANEL_RING_4, 2, ATTR_DIMMED, 1 );
(3,671 Views)
