LabWindows/CVI
Programming an Arduino with CVI
Wondering if someone could help me. I'm a LabVIEW user however have recently started to use CVI. I know with LabVIEW you can program the Arduino but wanted to know if you could do the same with CVI?
Sam
(5,949 Views)
Hi Sam,
I am an Applications Engineer at National Instruments. You must be already knowing that it's possible to program an Arduino in LabVIEW and in C. But I have not programmed an arduino using CVI before, and unfortunately haven't been able to find any documentation or examples on this. I think if you are more familiar with text based programming, it would be easier to simply do this in C because CVI is really C code.
NabilahF
(5,891 Views)
Labwindows is excellent to build the application that runs the driver compiled and loaded into the micro controller using the original Arduino IDE. The program and the driver can easily communicate via serial or Ethernet interface usind tcp or udp protocolls. All libraries are awailable on both systems.
(5,821 Views)
