LabWindows/CVI
Program lockup
Hello all,
a bit of a hurry here, I have a prog which locks up on one system but not on
the others. Used to run fine but I've done a lot of changes today.
It's CVI for Linux. Here's the core dump and it appears to loop inside a CVI
library function:
-- #0 0x0079f151 in __GetResDirPathString () from /usr/local/lib/libcvi.so
(gdb) bt
#1 0x0072fefd in __GetResDirPathString () from /usr/local/lib/libcvi.so
#2 0x007309d1 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#3 0x0070c08f in __GetResDirPathString () from /usr/local/lib/libcvi.so
#4 0x0070cce9 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#5 0x007b3fc1 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#6 0x00708e04 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#7 0x00706bca in __GetResDirPathString () from /usr/local/lib/libcvi.so
#8 0x00705cd5 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#9 0x00705dbf in __GetResDirPathString () from /usr/local/lib/libcvi.so
#10 0x0076a80b in __GetResDirPathString () from /usr/local/lib/libcvi.so
#11 0x00782dc4 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#12 0x007831fa in __GetResDirPathString () from /usr/local/lib/libcvi.so
#13 0x00783a9e in __GetResDirPathString () from /usr/local/lib/libcvi.so
#14 0x00783a86 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#15 0x00783a86 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#16 0x00783a86 in __GetResDirPathString () from /usr/local/lib/libcvi.so
#17 0x00808ad0 in CloseCVIRTE () from /usr/local/lib/libcvi.so
#18 0x00803f90 in MenuIsOpen () from /usr/local/lib/libcvi.so
#19 0xb7f19b0c in ?? ()
#20 0x00000001 in ?? ()
#21 0xbfdfed88 in ?? ()
#22 0x008010e8 in MenuIsOpen () from /usr/local/lib/libcvi.so
#23 0x00000002 in ?? ()
#24 0xb7f1ef20 in ?? ()
#25 0xbfdfed98 in ?? ()
#26 0x00888284 in ?? () from /usr/local/lib/libcvi.so
#27 0xbfdfeeb4 in ?? ()
#28 0xb7f1ef20 in ?? ()
#29 0xb7f1ef20 in ?? ()
#30 0x00000000 in ?? ()
Any hint ? I'll work on it more monday, gotta go.
Guillaume Dargaud
http://www.gdargaud.net/
Message 1 of 1
(3,085 Views)
