LabWindows/CVI
Program crash when i use SetBitmapToFile command in 16bit True colour.
i am using cvi 5.0 and i need to save a graph plot as a picture file. i used the SetBitmapToFile command from one of the examples from NI knowledgebase. this command cause a page fault in kernel32.dll when i run the program under 16bit high colour(display). it works fine when i use 32bit True colour but the saved bitmap is distorted. half of the image has purple lines running vertically across the pictures. Can anyone tell me how to solve this problems or give suggestion of any other methods.
thanks
Message 1 of 1
(2,887 Views)
