LabWindows/CVI
Problem with ProcessSytemEvents
i have upgrade from CVI 4 to CVI 5.0.1 and have several Problems to run my
old
programs written under CVI 4.0 with the Runtime Engine coming with CVI5.
My programs run much slower, then with CVI4.
I have compiled them under 5.0 but with no change.
I have find out that the problem occurs when i read something
from the comport (perhaps cause i use a while-loop).
For example:
In CVI4 the following code take about 3 second to complete, in CVI5 about 40
second.
while(!read_gps_wait_for( GPS_IDENT ) )
ProcessSystemEvents();
if (quit_program) return(0);
If i do not call ProcessSystemEvents() in the loop, the function need 3
second to complete,
but without ProcessSystemEvents() i can´t press a button to c
ancel.
Which is the difference between ProcessSystemEvents in CVI4 and in CVI5?
what was modified?
If i reinstall the RuntimeEngine coming with CVI4, everthing run fine.
Any help or advice would be appreciated and apology for my bad english
Best regards
Gregoire Diehl
(3,875 Views)
Gregoire,
The default sleep policy for CVI applications was changed in CVI 5.0.1. In
order to make CVI apps
behave better in a multitasking environment, the sleep policy was changed
from VAL_SLEEP_NONE to VAL_SLEEP_MORE.
You should read the SetSleepPolicy function panel help, and then decide on
which of the three values suits you best.
Luis Gomes
"Gregoire Diehl" wrote in message
news:3921152b@newsgroups.ni.com...
> Hello,
> old
en i read something
> For example:
40
> second.
> second to complete,
> but without ProcessSystemEvents() i can´t press a button to cancel.
> what was modified?
> Best regards
> Gregoire Diehl
(3,875 Views)
Dear Mr. Gomes,
That was the note, i searched for.
If i change the Value back to VAL_SLEEP_NONE ,
everything run fine.
Thanks for the fast support
Gregoire Diehl
(3,875 Views)
