LabWindows/CVI
Problem creating multiple XML attributes with the same attribute name
I am trying unsuccessfully trying to create multiple XML attributes with the same name as shown here in an example Microsoft configuration file:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
   <appSettings>
      <add key="Key0" value="0" />
      <add key="Key1" value="1" />
      <add key="Key2" value="2" />
   </appSettings>
</configuration>
I call the NewDocument, GetRootElement functions and then NewElement (appSetting), NewElement (add)
then I call AddAttribute with add, key & Key0 and again with add, value & 0.  This seems to work correctly but when I try to add the second pair of attributes key & Key1 and  value & 1 to element "add" it overwrites "<add key="Key0" value="0" />" and I end up with "<add key="Key1" value="1" />" only.
Am I doing something incorrectly or is CVI not capable of creating such an XML file?
(6,586 Views)
Accepted by topic author TomB@NASIC
Here is how you do it. I am not showing error checking to keep things simple.
#include <cvixml.h>
static void CreateAddElement(CVIXMLElement parent, const char *key, const char *value)
 CVIXMLElement add;
 CVIXMLNewElement(parent, -1, "add", &add);
 CVIXMLAddAttribute(add, "key", key);
 CVIXMLAddAttribute(add, "value", value);
 CVIXMLDiscardElement(add);
void main(void)
 CVIXMLElement root, appSetting;
 CVIXMLDocument doc;
 CVIXMLNewDocument("configuration", &doc);
 CVIXMLGetRootElement(doc, &root);
 CVIXMLNewElement(root, -1, "appSetting", &appSetting);
 CreateAddElement(appSetting, "Key0", "0");
 CreateAddElement(appSetting, "Key1", "1");
 CreateAddElement(appSetting, "Key2", "2");
 CVIXMLDiscardElement(appSetting);
 CVIXMLDiscardElement(root);
 CVIXMLSaveDocument(doc, 1, "c:\\temp\\temp.xml");
 CVIXMLDiscardDocument(doc);
(6,559 Views)
Thanks Mohan.
Message Edited by Snowman 6008 on 11-05-2009 09:18 AM
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(6,554 Views)
Thanks for the fix Mohan!  I didn't know you need to call the NewElement function each time you added an attribute.
(6,545 Views)
