LabWindows/CVI
Print Table all Line
Hello: I want to use all line printing function to print Table, because the print control function can only print visible, so could you tell me how to realize all the lines of print Table? Thank you ..
(4,285 Views)
You could create a temporary hidden panel, duplicate your table on it and arrange that table to show all columns, then print that table.
If the table does fit into a page it should perform well.
(4,279 Views)
Thank you for your reply
Also would like to ask you how to Table all the display panel to? Set what attributes?
(4,272 Views)
GetNumTableColumns
SetCtrlAttribute with ATTR_NUM_VISIBLE_COLUMNS attribute
Generally speaking, when seraching for a function or an attribute of a control you can right-click on the control itself and select Control Attributes of COntrol functions from the context menu: the help will be shown on the correspnding item, for example the list of attributes that can be used on a table
(4,266 Views)
