LabWindows/CVI
Print 2 panels with one comfirm?
I want to print 2 panels, one portrait, one landcape.
Is it possible to comfirm one, print to the same printer ?
PrintPanel doesn't return the printer used.
George Zou
Message 1 of 12
(5,559 Views)
Well, it does give the user a printer selector box if you pass '1' as the last parameter.
Message 2 of 12
(5,543 Views)
Then user has to comfirm twice.  That's what I try to avoid.
George Zou
Message 3 of 12
(5,536 Views)
Call it the 2nd time with 0...
But why do you need it both in landscape and portrait ? For maximal page occupancy ? Can't you just get the heigh and width of the panel and print in landscape if Width>Height and portrait otherwise ?
Message 4 of 12
(5,531 Views)
Then it prints to the default printer.
Might not be the one user wants.
I'm printing TWO different panels.
So I have to call prent panel twice.
There fore two comfirm ?!
George Zou
Message 5 of 12
(5,525 Views)
Accepted by topic author zou
You can enumerate printers in the system by using some Win32API calls this way (here I am filling a listbox with printer names on a button callback):
int CVICALLBACK EnumeratePrinters (int panel, int control, int event,
		void *callbackData, int eventData1, int eventData2)
  int            error = 0;
  int            i, numPrt, needed;
  PRINTER_INFO_1 *pi = NULL;
  char           *z = NULL;
  if (event != EVENT_COMMIT) return 0;
  //BOOL EnumPrinters(
  //	DWORD Flags,         // printer object types
  //	LPTSTR Name,         // name of printer object
  //	DWORD Level,         // information level
  //	LPBYTE pPrinterEnum, // printer information buffer
  //	DWORD cbBuf,         // size of printer information buffer
  //	LPDWORD pcbNeeded,   // bytes received or required
  //	LPDWORD pcReturned   // number of printers enumerated
  // Get required memory size
  EnumPrinters (
    PRINTER_ENUM_LOCAL,      // enumerate local printers
    NULL,                    // name of printer object
    1,                       // general printer info
    NULL,                    // printer information buffer
    0,                       // size of printer information buffer
    &needed,                 // bytes required
    NULL                     // number of printers enumerated
  // Allocate memory
  z = malloc (needed);
  memset (z, 0, needed);
  // Enumerate printers
  if (!EnumPrinters (
    z,                       // printer information buffer
    needed,                  // size of printer information buffer
    &numPrt                  // number of printers enumerated
    MessagePopup ("Error", "Error in EnumPrinters.");
    error = GetLastError ();
    goto Error;
  // Allocate structured memory
  pi = calloc (numPrt, sizeof (PRINTER_INFO_1));
  memcpy (pi, z, numPrt * sizeof (PRINTER_INFO_1));
  for (i = 0; i < numPrt; i++) {
    InsertListItem (panel, PANEL_LISTBOX, -1, pi[i].pName, i);
  SetInputMode (panel, PANEL_PRINT, 1);
Error:
  if (z) free (z);
  if (pi) free (pi);
  return 0;
The list of printers can be shown in a "options" panel where the user can select the printer to be used, next you can print with that printer this way:
int CVICALLBACK PrintSome (int panel, int control, int event,
  int  idx;
  char name[64];
  GetCtrlIndex (panel, PANEL_LISTBOX, &idx);
  GetLabelFromIndex (panel, PANEL_LISTBOX, idx, name);
  SetPrintAttribute (ATTR_PRINTER_NAME, name);   // Specify which printer to use
  SetPrintAttribute (ATTR_PRINT_AREA_WIDTH, VAL_INTEGRAL_SCALE);
  SetPrintAttribute (ATTR_PRINT_AREA_HEIGHT, VAL_USE_ENTIRE_PAPER);
  PrintPanel (panel, "", 1, VAL_FULL_PANEL, 1);
  return 0;
Nevertheless, this is somewhat not intuitive and you need to dig and study some of Win32APIs to obtain it. You may want to support this CVI idea for an independent command that displays the print dialog.
Message 6 of 12
(5,513 Views)
I forgot to say that:
  • You must #include <windows.h> to all source code where you are using this function
  • You must add winspool.lib to your project
  • You must delete "/DWIN32_LEAN_AND_MEAN" from the compiler defines in Options >> Build Options... panel or #undef the same string in source code before defining windows.h
Message 7 of 12
(5,508 Views)
This function is great !
I was working on PrintDlg last night.
Try to alter the default printer 😉
Enum printer is better.
I've some Windows API experience.
Why is that ?
George Zou
Message 8 of 12
(5,495 Views)
The amount of resources added to the IDE when including windows API can considerably increment compile time. For this reason that macro is provides: it defines a reasonable subset of the APIs which is worth for the majority of applications. In this particular case you cannot use it as it masks out commdlg.h from the compile, so you are missing necessary definitions and you get compile errors.
Message 9 of 12
(5,482 Views)
By the way, the NI Report function panel (nireport.fp) included with CVI has a function for getting the names of all the printers:
int NIReport_GetPrinters (char **Default_Printer, char ***All_Printers);
Martin
Certified CVI Developer
Message 10 of 12
(5,460 Views)
