LabWindows/CVI
PostDelayedCall for inits
Hello all,
is it correct to use PostDelayedCall() with a time of 0 before
any call to RunUserInterface so that the callbacks will indeed
be called upon entering RunUserInterface ?
I would like to set up a whole bunch of initialisations, but
util the interface is running I can't call the callbacks.
Guillaume Dargaud
http://www.gdargaud.net/
(3,122 Views)
Sorry, I just saw that it's not the same type of callback. I
wanted a way to call user interface callbacks only once the
interface is up and ready.
Guillaume Dargaud
(3,115 Views)
I suppose PostDeferredCall can suit your needs: as noted in the help for this function, the function is executed "in the main thread at the next occurrence of GetUserEvent, RunUserInterface, or ProcessSystemEvents", in your case immediately after RunUserInterface is called.
(3,112 Views)
