LabWindows/CVI
Possible bug in ToLittleEndian32 in CVI 2009
I ran the following sample code:
OutboundMsg.Header.Msg_ID = ToBigEndian32(FOO_MSG_ID);
DebugPrintf(“FOO_MSG_ID:        %d”,   FOO_MSG_ID);
DebugPrintf(“NATIVE:            %08X”, FOO_MSG_ID);
DebugPrintf(“BIG ENDIAN:        %08X”, OutboundMsg.Header.Msg_ID);
DebugPrintf(“LITTLE ENDIAN:     %08X”, ToLittleEndian32(OutboundMsg.Header.Msg_ID));
DebugPrintf(“LITTLE ENDIAN???   %08X”, ToBigEndian32(OutboundMsg.Header.Msg_ID));
And here is the output:
FOO_MSG_ID:           30
NATIVE:               0000001E
BIG ENDIAN:           1E000000
LITTLE ENDIAN:        1E000000
LITTLE ENDIAN???      0000001E
The line in red shows that the call to ToLittleEndian32 did no byte swapping.  Instead, only ToBigEndian32 actually did any byte swapping.  CVI says that a failed call to these endian functions will return 0.  It should not return exactly what was passed into it, as I’m seeing here.
Or am I missing something?
Thanks!
Tim O'Leary
(3,141 Views)
Accepted by topic author jtocwru
Functions dealing for endianness are located in toolbox instrument, whose code is distributed so you can check them by yourself.
As you can see here:
unsigned int CVIFUNC ToLittleEndian32(unsigned int n)
    if (HostIsLittleEndian())
        return n;
    return ToOtherEndian32(n);
 the function tests for system endianness and returns original number if the system is already little endian, which appears to be your case. This appears a correct behaviour to me.
The only condition for returning 0 is that ToOtherEndian32 () cannot discriminate system endianness; in every other case a number is returned.
(3,136 Views)
