LabWindows/CVI
PlotXY refresh
I am using LabWindows CVi 6.0. I'm a part time programmer. I have developed a small application to acquire data and plot using PlotXY() function. I have to acquire data from 6 pressure transducer equipments and then plot 2 parameters for each equipment. I'm not able to refresh (clear or delete) the previous traces of plot, when I select new parameters to plot. I use a timer to update plotXY function. I have ListBox to select equipment. I tried many options for Plot in GUI, DeleteGraph() function still not successful.
Peice of code which I used during my app development attached below. Am I missing something here?..
// Function to select Equipment/Parameters
int plotIdWt=0, plotIdLR=0;
int CVICALLBACK PlotDataFunctionCB (int panel, int control, int event,  void *callbackData, int eventData1, int eventData2)
 unsigned long int Tcount=0;
 switch (event)
  case EVENT_COMMIT:
   GetCtrlVal (panel, PLOTPANEL_EQUIPMENT, &plot_ctrlVal);
   SetCtrlAttribute (panel, PLOTPANEL_TIMER01, ATTR_ENABLED, 0); // Disable Timer
   SetCtrlAttribute (panel, PLOTPANEL_PLOT, ATTR_DATA_MODE, VAL_DISCARD);
   DeleteGraphPlot (panel, PLOTPANEL_PLOT, plotIdLR, VAL_DELAYED_DRAW);
   DeleteGraphPlot (panel, PLOTPANEL_PLOT, plotIdWt, VAL_DELAYED_DRAW);
   //RefreshGraph (panel, PLOTPANEL_PLOT);
   plotIdWt = plotIdLR = 0;
   SetCtrlAttribute (panel, PLOTPANEL_TIMER01, ATTR_ENABLED, 1); // enable Timer
   //MessagePopup("Message", "plotting Data complete");
   break;
 return 0;
int CVICALLBACK CallPlotTimeFunction (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
   switch (event)
  case EVENT_TIMER_TICK:
   SetCtrlAttribute (panel, PLOTPANEL_PLOT, ATTR_DATA_MODE, VAL_RETAIN);
   plotIdWt = PlotXY (panel, PLOTPANEL_PLOT, timeA, PTR_WtArray[plot_ctrlVal-1], timeCount,VAL_DOUBLE, VAL_DOUBLE, VAL_CONNECTED_POINTS,VAL_ASTERISK,    VAL_SOLID, 1, VAL_DK_GREEN);
   //SetPlotAttribute (panel, PLOTPANEL_PLOT, plotIdLR, ATTR_PLOT_YAXIS,  VAL_RIGHT_YAXIS);
   plotIdLR = PlotXY (panel, PLOTPANEL_PLOT, timeA,PTR_LRArray[plot_ctrlVal-1], timeCount, VAL_DOUBLE,VAL_DOUBLE, VAL_CONNECTED_POINTS, VAL_ASTERISK,VAL_SOLID, 1, VAL_DK_BLUE);
      SetPlotAttribute (panel, PLOTPANEL_PLOT, plotIdWt, ATTR_PLOT_YAXIS,  VAL_LEFT_YAXIS);
   break;
 return 0;
Thanks & Regards,
 Joy Gomes.
(4,218 Views)
I noted that in your timer callback you are drawing new plots reusing the same plot handles, so all previous plotted plots are no more individually accessible. Nevertheless, I suppose that when changing equipment shown you want that all plots are deleted from the graph, not only the last one drawn whise plots have been saved. I suggest you to pass -1 as the plot handle to DeleteGraphPlot and to use VAL_IMMEDIATE_DRAW, so that all plots are immediately deleted from the graph: the next time the timer callback executes the first diagramp for the new equipment will be shown.
(4,202 Views)
Thanks for valuable suggestion. I shall try.
 Joy Gomes.
(4,192 Views)
