LabWindows/CVI
PlotStripChart() causes stack overflow.
I am gathering binary data from an RS232 port at 115,200baud and at 1
character every 125us.
I have a com callback installed to handle the data and a global variable
in which to put it.
The data is written to file and plotted on a strip chart.
After about 5 seconds (around 43,000 bits of data), PlotStripChart()
causes a stack overflow.
The code is below, can anyone see why this is happening? The variable
'count' was added for debugging and is always in the order of 43,000
when the stack overflows and the variable 'read' is always exactly 16.
/* Global. */
char data[40000];
/* Com port configured. */
status = OpenComConfig (port, "", 115200, 0, 8, 1, 32767, -1);
/* Callback installed. */
status = InstallComCallback (port, LW
RS_RECEIVE, 100, 0, comCallback,0);
/* This function is called when there is data in the RS232 input queue
to be fetched. */
void CVICALLBACK comCallback (int COMPort, int eventMask, void
*callbackData)
/* Variables. */
int len, read;
static int count = 0;
/* Loop while there is data to be fetched. */
while( 0 < (len = GetInQLen (port)) ){
/* Limit the amount fetched to the size of data[] */
if(40000 < len)
len = 40000;
/* Read the data and note how many bytes where actually
read. */
read = ComRd (port, data, len);
/* Write the data to the file. */
fwrite (data, sizeof(char), len, fp);
/* Display the data. */
SetCtrlVal(panelHandle,PANEL_NUMERICMETER,data[read-1]);
PlotStripChart (panelHandle, PANEL_STRIPCHART, data,
read, 0, 0, VAL_CHAR);
count+= read;
/* Keep the UIR updated. */
ProcessSystemEvents();
John Cameron.
Type softly, read gently.
(4,001 Views)
In message <5AOL$SBArbnBFAhV@ob5.co.uk>, John Cameron
writes
>Hi,
>in which to put it.
Sorry, that should be bytes of data.
>/* Global. */
>char data[40000];
>status = InstallComCallback (port, LWRS_RECEIVE, 100, 0, comCallback,0);
>to be fetched. */
>*callbackData)
> /* Variables. */
> int len, read;
> if(40000 < len)
> len = 40000;
>read. */
> count+= read;
John Cameron.
(4,001 Views)
John,
Try changing ProcessSystemEvents() to ProcessDrawEvents().
Updating numerics and plotting points on graphs is a relatively slow process. If you have called RunUserInterface() in main() and you are still having to call ProcessSystemEvents() then your callback is not returning or is being called repeatedly.
You should not have to call ProcessSystemEvents() or ProcessDrawEvents() at all.
Jamie
(3,996 Views)
