LabWindows/CVI
Picture button with help text
I created several picture buttons. Now I'm searching for a solution to display a short explanation text, when the mouse cursor stays over the button.
Br
Andreas
(3,862 Views)
> Hi, I created several picture buttons. Now I'm searching for a
> solution to
> button.
SetCtrlToolTipAttribute() in the programmer's toolbox.
Guillaume Dargaud
http://www.gdargaud.net/
(3,854 Views)
Thank you
Andreas
(3,837 Views)
Hmmm, I just tried to use that function on one of my projects... and it does
nothing !
Does it need special setup ? Extra events ?
Guillaume Dargaud
(3,826 Views)
I'm using Labwindows/CVI 9.0.
You also have to enable the tooltip for each control.
e.g.
SetCtrlToolTipAttribute (pnlHndle_main, PANEL_PAUSEPLAY_SYMBOL, CTRL_TOOLTIP_ATTR_TEXT, "Pause");
SetCtrlToolTipAttribute (pnlHndle_main, PANEL_PAUSEPLAY_SYMBOL, CTRL_TOOLTIP_ATTR_ENABLE, 1);
and it seems, that it doesn't work, if the control is dimmed, but that's OK.
You also have to stay a little bit on the control and do nothing, than it will be displayed. Afterwards you have to move the cursor far away, that it will be displayed again.
But it works.
Br
Andreas
(3,824 Views)
