LabWindows/CVI
Picture Ring problem !
Hi all,
I have created a child panel "panel5" beside main panel "panelHandle" and put inside a Picture Ring control with four pictures (their indexes are 0,1,2,3 ) for animation...
When there is a function called, it will display panel5 and the animation will start. But when I run my code, it was stationary :(. Could you guys advise me on where my mistake was ? Thx thx a million time.
        LoadPanel (0, "fyp.uir",4 ); // Load panel5 in memory
        SetPanelAttribute (panelHandle, ATTR_VISIBLE, 0); // Set invisibility for panelHandle
        SetPanelAttribute (panel5, ATTR_TITLE, "Loading MCQ data !"); // Set title of panel 5
        // Convert and set attributes for Picture Ring
        AnimateCtrl_ConvertFromPictRing (panel5, PANEL5_PICTURERING);
        AnimateCtrl_SetAttribute (panel5, PANEL5_PICTURERING, ATTR_ANIMATE_ENABLED, 1);
        AnimateCtrl_SetAttribute (panel5, PANEL5_PICTURERING, ATTR_ANIMATE_FRAME_INTERVAL, 1);
        AnimateCtrl_SetAttribute (panel5, PANEL5_PICTURERING, ATTR_ANIMATE_STOP_ON_LAST_FRAME, 0);
       // end setting
        DisplayPanel (5);  //display panel5
        SetPanelAttribute (panelHandle, ATTR_VISIBLE, 1);
        HidePanel (panel5);
(3,420 Views)
Hi Mavn2002,
I made a very brief program on my end and was able to see my picture ring "spinning".  Here is the code snippet which most applies to your application:
    panelHandle = LoadPanel (0, "Test.uir", PANEL);
    DisplayPanel (panelHandle);
    AnimateCtrl_ConvertFromPictRing(PANEL, PANEL_PICTURERING);
    AnimateCtrl_SetAttribute (PANEL, PANEL_PICTURERING, ATTR_ANIMATE_ENABLED, 1);
    AnimateCtrl_SetAttribute (PANEL, PANEL_PICTURERING, ATTR_ANIMATE_FRAME_INTERVAL, 1);
    AnimateCtrl_SetAttribute (PANEL, PANEL_PICTURERING, ATTR_ANIMATE_STOP_ON_LAST_FRAME, 0);
    RunUserInterface ();
I hope this helps!
Matt S
(3,375 Views)
