LabWindows/CVI
Period Measurement Issue
I am using one of the counters in a PXI 6221 board to measure the period of a pulse train to implement a tachometer. Everything works fine when connected to a signal generator on the bench but when used with a more noisy signal with occasional glitches it will sometimes stop generating new data.
The initalization code is:
DAQmxCreateTask("FInputs",&FreqHandle);
 /* add a frequency channel to read RPM */
err = DAQmxCreateCIPeriodChan (FreqHandle,FIRST_6221"/ctr0" ,"", 0.0001, 0.1, DAQmx_Val_Seconds, DAQmx_Val_Rising,  DAQmx_Val_LowFreq1Ctr, 0.000001, 4, "");
DAQmxCfgImplicitTiming(FreqHandle,DAQmx_Val_ContSamps,0);
DAQmxSetBufInputBufSize(FreqHandle, 1000 );
DAQmxStartTask(FreqHandle);
Then the following is called every mSec when a reading is needed:
err = DAQmxGetReadAvailSampPerChan(FreqHandle, &num_avail);
if (err != 0)
        DAQmxGetErrorString(err, err_msg, 100);
        printf("From GetRead... %s \n", err_msg);
if (num_avail == 0)
        /* no new periods measured, dont update speed so previous data used again
         * clear bit in status
        status &= ~STATUS_TACH_PULSE_RECVD;
        no_pulse_cnt++;
        if (no_pulse_cnt > 1000)
            no_pulse_cnt = 0;
            DAQmxStopTask(FreqHandle);
else
        err = DAQmxReadCounterF64(FreqHandle, DAQmx_Val_Auto, 0.0 , data_array,1000,&num_avail , NULL);
        if (err == 0)
             /* sum all availible periods */
            for(i = 0; i < num_avail; i++)
                 Period += data_array[i];
            if (Period > 0.0)
                 /* calculate RPM from average measured period between pulses from sensor */
                 *speed = PERIOD_SCALE*num_avail/Period;
             /* set flag to indicate pulse(s) received */
            status |= STATUS_TACH_PULSE_RECVD;
       else
            /* error condition, use max speed */
            *speed = 9999;
            printf("From ReadCounter...  %s \n", err_msg);
When the problem shows up, num_avail from DAQmxGetReadAvailSampPerChan will remain at 0  even though
there are pulses on the input.  No errors are detected.
I have implemented a timeout (based on the no_pulse_cnt variable) that Stops and Starts the task when this
happens. This gets things working again but I am looking for a cleaner solution that prevents the issue or allows me to detect it immediately.
Looking in the Archives I have seen some comments about issues which can happen when there are no
timebase pulses between input edges.  Could this behavior be triggered by that?
Jim
(3,568 Views)
Does this problem occur using one of the DAQmx text based examples?
-Ciao 😉
(3,526 Views)
I have looked at the examples, but none seem to do exactly what I am looking for as far as providing the latest period data on demand.   I am doing this under the real time OS so I cant simply run the examples anyway.
In the meantime we have improved our external signal conditioning circuitry and the problem has effectively disappeared.   I would still like to improve the robustness if practical though.
Jim
(3,492 Views)
