LabWindows/CVI
Pattern Information, Display Mask
we use NI Vision 8.2. Exactly we use the CVI imaq library in our own application. The task for which we use is geometric pattern matching. I have create a tool which looks like the Vision Assistent. I can change all the option, learn pattern and match with my source image. Read and Write the picture is not a problem. Creating a image mask and set points to ignore and other points to curve points is also not a problem.
So here my questions:
When i load a patterfile via "imaqReadVisionFile", how can i get the "curveOptions" information, advancedLearnOptions and how i get the pattern mask from the pattern file?
Greetings
Mirko
(3,468 Views)
Hi Mirko,
the NI Vision library in CVI offers different functions that should be helpful to your question in "Pattern Matching":
imaqLearnGeometricPattern (, IMAQ_NO_OFFSET, NULL, NULL, NULL);
imaqReadMultipleGeometricPatternFile (, NULL);
For more information about the elements of CurveOptions refer to the NI Vision for LabWindows/CVI Function Reference Help in the Vision Development Module Bookshelf. To access the bookshelf, select Start>>All Programs>>National Instruments>>Vision>>Documentation>>Search the NI Vision Bookshelf..
regards,
Nikolai
(3,415 Views)
In this illustrative example, we will create a program in Labview capture an image pattern, after the search to show the location and coordinates, you can check the following article in the following link
https://decibel.ni.com/content/docs/DOC-31880
(3,004 Views)
