LabWindows/CVI
Panel State File Encryption
Using the SavePanelState() function generates a file that exposes too much information, with even simple tools such as notepad.  How can this file be best program inline encrypted?
(4,832 Views)
The only way that comes to mind is that you can save the state in a temporary file, and then encrypt it into a final file.
Someone could obviously intercept the file before its cancellation.
Carlo A.
Megaris srl
Italy
(4,800 Views)
You can encryip the content of you panel controlls before saving and save the panel with the encrypted data. It works with text and numbers, I am not sure if it works with graphs. Alas, there is no encryption library for CVI. I miss that very much. Maybe if we demand it, the next version will include some simple crypto libtary ir device driver/wrapper for windows encryption programming interface. The one awailable is too complicated, and one has to spend many many hourse to be able to use it. Even than I am not sure I am doing it right.
I really want a VERY simple library: create a context, manage passwords and logins and encrypt/decrypt a block of memory preferably into encrypted string data type that can be easily manipulated, saved, sent or loaded read. But a binary firmat would work well too.
(4,790 Views)
A good way to make sure that the developers for CVI see this idea would be to post it in the LabWindows/CVI idea exchange:
https://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/idb-p/cviideas
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(4,778 Views)
