LabWindows/CVI
PXIe 1082 Fan Control using LabView or CVI
Hello NI Community,
I was trying to run the PXie fan control CVI example located at https://www.ni.com/en-us/support/documentation/supplemental/16/changing-the-fan-mode-programmaticall...
with the NI PXIe-1082.
For some reason I cannot get any information out of the PXIe using this code.
Every time I try to get Fan speed or Fan Mode i receive the following error
-2147220623 The property does not exist for this resource.
Similarly when I modify the Labview code to control the PXIe, it gives the same error.
I wanted to ask whether the PXIe-1082 is Fan controllable ? Is it compatible with the code above. ( I know it does not call out this PXie in the description but i wanted to double check if this is indeed the case)
Kishen
Message 1 of 1
(1,995 Views)
