LabWindows/CVI
PCIe 6537
I am looking to use PCIe 6537 and I am seeing if anyone has used CVI to interface to it?
Is there any sample code around?
Simon
(3,677 Views)
Did you install NI-HSDIO ?
Probably there will be some samples coming from that installation.
S. Eren BALCI
IMESTEK
(3,672 Views)
Hello Simon,
The first thing you will need to make sure of is that you have installed NI-DAQmx.  This is the driver necessary to communicate with your instrument.  Also, this driver will install some example programs that can be accessed from the NI Example Finder (Help » Find Examples) in CVI.  You can find these in the NI Example Finder by going to Hardware Input and Output » DAQmx, and then looking at any of the digital folders.  This should be a good start but please let me know if there is any type of example in particular that you are looking for.
(3,651 Views)
A useful tutorial for call the DAQmx API from CVI...
Using NI-DAQmx in LabWindows/CVI
http://zone.ni.com/devzone/cda/tut/p/id/2931
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,630 Views)
