LabWindows/CVI
PC-LINT
Does anyone have a lnt file for CVI or can recommend one of the examples that comes with pc-lint?
I would like to use lint since the compilier didn't even flag the following and I am wondering what else is not being flagged!
char a = 1024;
(3,813 Views)
Which version of CVI are you using? Versions after 2013 (inclusive) use the Clang compiler, which has a large number of warnings you can turn on. I normally run with all warnings enabled apart from the exceptions below.
Your code snippit would be caught by the "Constant conversion" warning. The compiler warning would be " warning: implicit conversion from 'int' to 'char' changes value from 1024 to 0".
(3,784 Views)
