09-09-2005 12:37 PM
09-12-2005 01:42 PM
Hello Geetha,
Can you provide me with some exampe code that shows your problem. For the first one, is it any one particular panel that is causing the problem? If so, can you send that uir file to me and also show me how you are loading it.
For the second problem, how are you declaring the shared memory? What function calls are you using to access the memory. Again, a small example program would be most valuable.
Jack J.
Applications Engineering
