LabWindows/CVI
Out of memory using InsertListItem(....)
The listed source result in a :
 NON-FATAL RUN-TIME ERROR:   "NaviLightsSignalsGUI.c", line 46, col 13, thread id 0x00000728:   Library function error (return value == -12 [0xfffffff4]). Out of memory
#define PREDEFINED_TEXT_NAME  "text_"
#define NO_OF_CARD     49
char gPictureFileName[256];
int gPanelHandle, i;
 for (i=1; i<= NO_OF_CARD; ++i) {
  sprintf(gPictureFileName, "%s%d.jpg", PREDEFINED_TEXT_NAME, i);
  InsertListItem(gPanelHandle, PANEL_PICTURERING, -1, gPictureFileName, 0);
The question is why and how to overcome this issue?
Regards
EGO
(3,534 Views)
One possible reason could be that you are passing a .jpg file whereas the picture ring control accepts only bitmap images. You could try to use GetBitmapFromFile to retrieve the bitmap out of you jpeg files and SetCtrlBitmap instead of InsertListItem: according to SetCtrlBitmap online help:
For picture rings, you can use this function instead of ReplaceListItem. To add a new entry, first call InsertListItem with a NULL value and then call SetCtrlBitmap.
(3,514 Views)
Thank you for the answer,
I will try it ASAP
Regards
EGO
(3,507 Views)
