LabWindows/CVI
Out of mem with ClipboardGetBitmap()
I always get an out of memory error when I call
Error=ClipboardGetBitmap (&BmpID, &Available);
even if the bitmap currently in the clipboard is very tiny.
What's wrong ?
Do I have to call something before ?
Guillaume Dargaud
CNR/IFA
http://sung3.ifsi.rm.cnr.it/~dargaud/
http://sung3.ifsi.rm.cnr.it/~domec/
http://sung3.ifsi.rm.cnr.it/~chooyu/
"Chess is a foolish expedient for making idle people believe they are doing
something very clever when they are only wasting their time." - George
Bernard Shaw.
Message 1 of 9
(5,519 Views)
I agree.
I wanted to something like this, but same error as Dargaud with CVI 8.0.Smiley Mad
Someone can help?
Thanx.
    hdc = GetDC(DeskHwnd);
    hdcMem = CreateCompatibleDC(hdc);
    hBitmap = CreateCompatibleBitmap(hdc, fwidth, fheight);
    if (hBitmap != 0)
        SelectObject(hdcMem, hBitmap);
        // Copy the Desktop bitmap to memory location
        // based on window coordinates.
         junk = BitBlt(hdcMem, 0, 0, fwidth, fheight, hdc, rect.left, rect.top, SRCCOPY);
        // Set up the Clipboard and copy bitmap
        junk = OpenClipboard(DeskHwnd);
        junk = EmptyClipboard();
        SetClipboardData(CF_BITMAP, hBitmap);
        junk = CloseClipboard();
        ClipboardGetBitmap (&iBitmap, &junk);
        CanvasDrawBitmap (panel, PANEL_CANVAS, iBitmap, VAL_ENTIRE_OBJECT, VAL_ENTIRE_OBJECT);
        DiscardBitmap (iBitmap);
    // Clean up handles
    junk = DeleteDC(hdcMem);
    junk = ReleaseDC(DeskHwnd, hdc);
Message 2 of 9
(5,374 Views)
Hi bicoun,
I was able to replicate your error, but could not find a way to correct it. As such, I have filed a Corrective Action Request with the appropriate sources to find a solution for this problem.
In the meantime, I have attached an example that I believe you can use as a workaround. In the attached example, a bitmap is written to and retrieved from the clipboard. With a few modifications, I believe it should be able to solve all of your problems.
Matt Mueller
NI
Message 3 of 9
(5,330 Views)
I apologize - I appear to have forgotten to post the example. However, the example is posted in the National Instruments Developer Zone at Transferring Images and Text with Clipboard Functions.
Message 4 of 9
(5,310 Views)
Dear all,
I have run this example, but when I close, it show a panel as the attachment!
Do you know what's wrong with my computer please?
帖子被Jaman在08-18-2006 05:42 PM时编辑过了
Best regards
Jaman
Developing Test Sepcialist
Message 5 of 9
(5,274 Views)
I am also seeing this out of memory error when I call ClipboardGetBitmap function. It works for about 89 times before it breaks. It seems like this issue is not fixed in 8.01 version.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Message 6 of 9
(4,979 Views)
Hello
This issue has been fixed for CVI 8.1. If you would like to verify it, you can download the eval version of 8.1 and test it out.
Bilal Durrani
NI
Message 7 of 9
(4,951 Views)
for people who is still using older versions try discarding bitmap(DiscardBitmap) after ClipboardGetBitmap function. Call DiscardBitmap function before you call ClipboardGetBitmap  again.
It fixed problem in my application. ClipboardGetBitmap function help does not tell you to do this.
Thanks to NI application engineer.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 8 of 9
(4,947 Views)
Actually the help for the bitmap ID parameter for ClipboardGetBitmap does mention this. I checked versions 8.0.1 and 8.1.
ID that serves as a handle to the bitmap copied from the clipboard.
You can pass the bitmap ID to CanvasDrawBitmap and to other bitmap functions.
When you no longer need the bitmap, free it by passing the ID to DiscardBitmap.
If there is no bitmap on the clipboard, bitmapID is set to NULL. If you want to check whether a bitmap is on the clipboard but do not want to retrieve it, pass 0 for this parameter.
Bilal Durrani
NI
Message 9 of 9
(4,920 Views)
