LabWindows/CVI
Out of Memory- LabWindows/cvi
I have a problem with labwindows/cvi, when I build and execute my proyect the following error appear:
Out of Memory - An error ocurred while loading debugging information. Is this DLL/EXE was built with an earlier version of Labwindows/cvi you might have to rebuilt it using this version.
If the folder cvibulid.myproyect has not been created yet there is no problem. But if i build my proyect and the I made changes and try to rebuilt, It is it that moment when the error ocurred. So I have to delete the folder every time I made a change If I don´t want the error appear.
I have been working with this version of Labwindos/cvi (7.1) and with this proyect for a long time and i haven´t got any problems, I don´t Know if it could be a build option in the cvi or where could be the problem.
Thank you very much in advance,
(3,833 Views)
Please read this forum message and check if any of the solutions suggested work in your case,
Let me know,
Jaime Cabrera
NI Applications Engineering Spain
(3,762 Views)
Hi Jaime,
Yes, I tried with the suggestions from the link you show me, but the problem went on.
But now, it is ok. I don´t know why, but when I remove from the proyect one .c file it works correctly.  This file is similar to other used in the proyect without problem, so I have to study the reason. If I find the error I will let you know.
Thank you,
(3,729 Views)
It seems like that c file was done in a previous version of CVI and was not build with the 7.1, so that file is giving u problems.
Well, the important thing is that it is working properly now,
Jaime Cabrera
(3,723 Views)
just to make sure: is the 'O' option enabled on this particular file ?
to check this, right click on the file and look at the menu: if it says "disable 'O' option", it means the option is enabled.
(3,716 Views)
