LabWindows/CVI
OpenCV settings to run OpenCV project in LabWindows/CVI
Hello!
I know this is a simple task here and i would appreciate anyone who knows about this can help me to get started with it.
I want to use OpenCV library in Labwindows/CVI. What settings do I have to make in order to run a simple code. I know what settings to do in Visual Studio. Like adding directory paths under Library files, Include files, Source files,...etc.
So what settings do I need to make in Labwindows in order to start a simple openCv project. I would appreciate a link or some instruction guidelines.
Thank you so much folks!
(4,393 Views)
setup is the same for CVI, except that options are not at the same place.
for CVI, include paths are specified in the "Edit/Project..." menu, there is an "Include Paths..." button. the list is valid for all type of includes (library, header, source...). if you need to set some compiler options (#define), it is in the "Options/Build Options..." menu, at the very bottom of the window.
now, i would recommend adding the lib and header files directly to your project. this will allow anyone who needs to compile your project to be aware of the dependency.
(4,360 Views)
