LabWindows/CVI
OT: virtual drive API
Sorry if this is a bit off topic.
I'm rusty with the Windows API and I spent some time in the msdn
documentation trying without success to figure out how to create a
virtual filesystem: Something mounted as, say, F:\ in windows, but
controlled by a C program, all the directories and files created on the fly.
This is basically the way programs such as SftpDrive, PowerIso and
others work.
Any idea where to start ?
Guillaume Dargaud
http://www.gdargaud.net/
(3,652 Views)
Hi Guillaume,
I think what you're trying to do can be done with the "subst" command.  Below is the link to its syntax.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/subst.mspx?mfr=true
Gavin Fox
Systems Software
(3,625 Views)
Hello Gavin,
> Guillaume,I think what you're trying to do can be done with the
> syntax.http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/subst.mspx?mfr=true
Not at all. The old DOS subst command simply remaps one drive to another.
I would like to write a service that when the OS tries to access, say,
F:\somedir\somefile.txt
the file (and the directory structure) gets created on the fly by my
program. A virtual drive.
There are programs that do this (TrueCrypt, SftpDrive, PowerIso...) for
specific applications (encrypting a drive into a file, showing an ssh
connection as a drive, showing an iso as a drive...)
I imagine there are plenty of special windows API calls involved but I
don't even know what they are called.
Guillaume Dargaud
(3,612 Views)
Hi Guillaume,
There isn't anything in CVI that directly does this.
You're welcome to post on our BreakPoint discussion forum.
http://forums.ni.com/ni/board?board.id=BreakPoint
Gavin Fox
Systems Software
(3,588 Views)
