LabWindows/CVI
Numeric Ctrl value not selectable?
Hi Happy CVI'ers,
I'm just looking after a little trick:
I display intruments values in numeric controls. Not editable, no
cursors, ... just display a value wich is refreshed every 30s.
However, the user can select the caracters inside the control. As the
background and text color change upon alarm state, I have some noisy
inverse colors with the selected part.
Is there any way to avoid selection in a not editable control (numeric
or text)
Thanks for any help,
Fred
(3,010 Views)
Sure, just swallow the left click event. See the CVI help for a discussion of swallowing events. Basically, you would just catch the left click event in a callback on the textbox or numeric and return a positive number. For example,
int CVICALLBACK TextCB (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_LEFT_CLICK:
return 1;
break;
return 0;
This will abort the normal processing of the left click, so the control will not get the focus and their can be no selecting.
Best Regards,
Chris Matthews
(3,010 Views)
