LabWindows/CVI
No error message or warning in build output, but build fails
Hey rdwitt,
I'm glad the workaround helped you. However, we need to track the issue you described.
You said you were using Windows 7 Enterprise SP1 64 Bit. Does Help>About LabWindows/CVI display the correct build number after upgrading? It should be 13.0.0 (647).
Did you install a language pack for Windows 7?
Thank you,
=Nelu F. || National Instruments.
Message 11 of 11
(1,234 Views)
